Phonebook has stopped working
Suburban_fox
I missed a call from somebody today, and when I touched the "Phone" application to find out the time of the call, I got the following message:
"The application Contacts (process com.sonyericsson.android.social phonebook  has stopped unexpectedly. Please try again."
I now get this message every time I attempt to use the phonebook, which basically means I can no longer make calls. I can still receive calls, and everything else seems to work okay.
Shutting down the phone and re-starting it did not fix the problem.
Alexander1
Champion
We have identified this issue on some units and the source of issue resides in a Google Play Services update (4.4.49). Google has been contacted about this and have confirmed a fix for Google Play Services version 4.4.50 or higher. In the mean time you can either remove any accounts that depend on Google Play Services like, Facebook, Viber, Skype etc. You can also choose to uninstall the latest Google Play Services update but then losing access to some Google applications.
81 REPLIES 81
Alexander1
Champion
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
First of all try to clear data for phone under settings > apps > all > phone > clear data > restart the phone and try again.
Let me know how it works out.
abc_123
Hey ,
I've got same problem with my Xperia U , cant make calls. Everything seems working.
Removed battery , restarted the device. Did factory resore nothing. Please advce.... very important...
Suburban_fox
I can't see a 'phone' option listed. The closest I could find to the path specified was:
Settings > Applications > Manage Applications > All
But there's no 'phone' option there.
eta: the actual making of calls seems to be working...if I can access a number via the text message screen, then I can dial out. But I can't access any other contacts, or dial any new numbers, because I can't get to the dialler.
sloane9411
hey
has anyone found a souloution yet as i need to have my phone book A.S.A.P i am very wound up bout this
gemma
I have had this same message today, everything else is fine, but can't get into contacts and can't make calls.  I have reset my phone to factory settings and it still doesn't work
dimpyrox
Hi, I followed the instructions that were stated and restarted my phone but the problem still persists. I am not able to access neither my phonebook neither my contact list. This has been happening for over 24 hours now. Please help.
Karthika
I am facing issue on accessing the phonebook application.Please provide any resolution,else i may have to think out of xperia.
Aalaa
hi,,
I Have thw same problem ,, any update please ???
Steve_V
This exact problem also started to happen on my phone yesterday - now a problem for 24 hours despite switching off etc. Could someone please provide some guidance to resolve? I am unable to access my contacts or make phone calls. Thanks.
