Hello I have a Sony phone lt28h unlocked i Purchased from iraq, but my phone stopped receiving the network after two months I entered Turkey.
please help me find a solution to my problem. Peace
Topic edited by Rickard
Telecommunications company trying to steal because I bought the device is unlocked and works in each of the networks they are downloaded to withhold my telephone service for two months after
And used the second and third phone every time stops after two months. Is there a legal solution
This condition occurs with each device brought from outside Turkey that is, they generally in Turkey, but I recently moved and I want to buy a new device from Turkey. Any idea to help in the solution you have
I apologize, but I will go now, thank you for your responses
Greetings
I hope that you complete later
From what i've been able to find, if you bring a phone from outside of Turkey it will work for a while without being registered in the country but if you plan to stay longer it needs to be registered. If you don't register it, it will be blocked after a while.
See these links for example:
http://www.turkishconsulate.org.uk/en/other_services.asp?PageID=12
http://www.turkeytravelplanner.com/details/Communications/registration.html
thank you In this case, buy a new device best
