Phone doesn't work in Turkey
5060563940
Hello I have a Sony phone lt28h unlocked i Purchased from iraq, but my phone stopped receiving the network after two months I entered Turkey.
please help me find a solution to my problem. Peace
Topic edited by Rickard
16 REPLIES 16
5060563940
Telecommunications company trying to steal because I bought the device is unlocked and works in each of the networks they are downloaded to withhold my telephone service for two months after
  And used the second and third phone every time stops after two months. Is there a legal solution
Thommo
I don't know - This sounds like an issue between you and the networks - Phones don't work fine then after two months stop on different handsets
5060563940
This condition occurs with each device brought from outside Turkey that is, they generally in Turkey, but I recently moved and I want to buy a new device from Turkey. Any idea to help in the solution you have
5060563940
I apologize, but I will go now, thank you for your responses
  Greetings
I hope that you complete later
Rickard
Master
From what i've been able to find, if you bring a phone from outside of Turkey it will work for a while without being registered in the country but if you plan to stay longer it needs to be registered. If you don't register it, it will be blocked after a while.
See these links for example:
http://www.turkishconsulate.org.uk/en/other_services.asp?PageID=12
http://www.turkeytravelplanner.com/details/Communications/registration.html
5060563940
thank you In this case, buy a new device best
Koozie
You need to register the phone with property identifications at the telephone genel dairesi.
