My Ray battery always speed to zero after reaches 20% mark. When it reaches 20% the phone will shut down itself. It's like the battery power runs out to 0% in few seconds after reaches 20%. Is there anything wrong with my phone?
take out the battery and reinsert it and charge it
observe its behaviour and it won't happen again
do tell the results
OK, will do. Once I got the outcome I'm gonna post it here. Thanks
OK it's working fine now. Thanks. By the way, do you know why a simple solution like that can fix this problem?
