My Ray battery always speed to zero after reaches 20%. Is my phone faulty?
My Ray battery always speed to zero after reaches 20% mark. When it reaches 20% the phone will shut down itself. It's like the battery power runs out to 0% in few seconds after reaches 20%. Is there anything wrong with my phone?
Nabeel
Master
take out the battery and reinsert it and charge it
observe its behaviour and it won't happen again
do tell the results
4 REPLIES 4
Nabeel
Master
do tell the results
OK, will do. Once I got the outcome I'm gonna post it here. Thanks Slightly_smiling_Face
OK it's working fine now. Thanks. By the way, do you know why a simple solution like that can fix this problem? Slightly_smiling_Face
aami
I have a xperia j and the same problem..After reinserting the battery should i turn my phone on and charge it? Or leave it turned off and charge it till green led light shows its fully charged? Help please
