messaging icon is missing in the applications.
ree
Messaging icon on Xperia sp is not found anywhere in the applications shortcut. I am not receiving any sms nor able to send one through the contacts
gwhispererz
Champion
Hi, kind of weird .... Anyway, a factory reset should fix it.
Make sure Back up my data and Automatic restore are ticked.
3 REPLIES 3
gwhispererz
Champion
ree
I did that and it works fine now. thanks.
gwhispererz
Champion
You are welcome. Slightly_smiling_Face
