Xperia SP notiification light doesn't work for missed call?
fuiboon
Hi, i just noted the notification light will light up for missed SMS, but it doesn't light up for missed call ... is it a software bug?
none if you want stamina mode to work as its supposed to, this should explain it
http://talk.sonymobile.com/message/458214#458214
8 REPLIES 8
fuiboon
realized it's due to the Battery Stamina Mode, turning it off will solve the issue, but strangely Missed SMS LED is not affected by the Battery Stamina Mode ...
you can exclude apps, just tap on stamina mode and add apps.
CM-Z
What applications need exclude?
Xperia_SP
Which Apps I have to add to STAMINA-Mode when I want to get LED Notifications for
- missed calls,
- missed sms,
- missed e-mails,
- missed facebook messages,
- missed calendar alarms?
Thanks a lot for your support.
eduardo
Any reply to your answer?
Bradley
My text notification has stopped working even with stamina mode off
Any ideas?
Bradley
Notification bar to clarify
