memory card not read
ivantec
No memory detected, install several and none work
profile.country.RO.title
_alexdon_
Take the phone to the closest sony service,tell them your issues.They can help you more,you might have some hardware issues.
alexdon
5 REPLIES 5
_alexdon_
Are you sure you insert it correctly?What memory cards did you insert?
alexdon
ivantec
Yes, I'am Ing. Sistemas, memory kingston micro sd, Of various types and brands of memory, does not recognize, just sometimes
_alexdon_
alexdon
ivantec
Memory card not found or is deactivated and Thank you very much 🙂
_alexdon_
You are welcome,keep us updated.
alexdon
