Material used for Xperia Ray
Nate88
I have been using the Xperia Ray for a couple of weeks and have enjoyed using it so much I bought a cheap newer-android handset to try aswell. I hate it though, as compared to the ray it feels light and fragile.
Please can anyone tell me what material is used for the ray?
Phy
Legend
Legend
@Nate88
You can read about it here
http://www.gsmarena.com/sony_ericsson_xperia_ray-review-649p2.php
"Part of the inner body of the Xperia ray is made of metal, which gives the phone excellent rigidity. Still, the outside is all plastic so you don't get the metal unibody feel you get from other phones."
7 REPLIES 7
Phy
Legend
Legend
@Nate88
Phy
Legend
Legend
@Nate88
Here is more info regarding the material used on this Xperia
http://www-support-downloads.sonymobile.com/st18/whitepaper_EN_xperia_ray.pdf
"•Elegant smartphone with aluminium frame, mineral glass"
Nate88
It is noticably different to the newer handset I have bought. It feels very solidly built.
Phy
Legend
Legend
How do you mean and which other android phone are you comparing it to?
Nate88
I like smaller phones, the ray especially feels very balanced in my hand. It has got a good weight and it is comfortable to hold when using for extended periods of time.
I have bought a vodafone android phone, its still pretty small but the screens a bit bigger, but it is light and feels easy to break.
I like the Xperia ray much more.
Phy
Legend
Legend
Have you considered the Xperia Z3 Compact?
Nate88
No, I have not seen the Z3 Compact. I will look at it though, thanks for the suggestion.
