Lock Screen touch problem
The touch input is not working properly when I try to unlock the phone by sliding the lock icon and even when using the visible pattern lock. I have to try multiple times before I am able to unlock it properly. Please reply,i don't no what to do to make it work,i have tried resetting the phones settings but that didn't work.
Nabeel
Master
ok now try a software repair... it might be a software glitch
Update/Repair your phone via SEUS or PCC
SEUS ( Sony Ericsson Update Service)  ... download it and install it on your pc and follow the on-screen instructionshttp://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
      PCC (PC COMPANION) – Repair your software with this .First do the setup without connecting your mobile to pc.(only connect when you are asked to). Do it as follow >> PCC > SUPPORT ZONE> SOFTWARE UPDATE> REPAIR SOFTWARE (written with blue)
Don't forget to mark the Correct Answers and Helpful Answers
24 REPLIES 24
Nabeel
Master
gwhispererz
Champion
Hi, one question first ....
Do you have a protective casing over the phone?
Yes the screen protector that was provided with the phone.
gwhispererz
Champion
No, I mean a protective casing, not screen protector. If none, it could be a software issue, you may follow Nabeelraza's advice to software repair phone.
No,I will try the steps mentioned hope it solves the problem.
Hi all friend.My phone mode xperia Neo. i have a problem with unlock screen. i must to mluti slide to unlock screen. even i try to reset phone factory, still cannot solve this problem.  Crying_Face
suze
Leader
One simple thing to try is to pause momentarily on the right hand side when you slide, rather than simply flicking across and taking your finger straight off.
Nabeel
Master
do what Suze said
and while unlocking/sliding, take care, not to touch anywhere else on the screen
if still you feel that the problem is getting worse then perform a software repair. it might be a software glitch . For it see my first post, above Slightly_smiling_Face
do tell the results Slightly_smiling_Face
Many thank for all reply i will try! 🙂
