how to make print screen with xperia v
lt25Gary
profile.country.RO.title
_alexdon_
Power button+vol down at the same time to take a screenshot.
alexdon
7 REPLIES 7
_alexdon_
alexdon
lt25Gary
alexdon thanks you so much
_alexdon_
Anytime.
alexdon
kenosisaeternum
For People who havent updated the Xperia V or
update simple do not exist for some  Xperia V  ...
Press the Power Button for some time (2sec), and will appear a menu wher you can apply that choice : )
_alexdon_
Thanks but I think many of them already know that,the problem is after 4.3 update.
alexdon
NeelK
After upgrading, i lost screen shot option.
Does anyone can help on this.
Build Number: 4.1.A.0.562
foofighter88
i have xperia v and z3 tablet compact. screen cap function is not very user friendly,
