Home screen rotates to landscape in ICS, but only when charger plugged in .anybody noticed this?
or Am I the only one who is facing this?
Yes, it's something to do with that app. I re-enabled the app and cleared the data, and it's working. Rotates to landscape without problems.
It rotates for me without the charger plugged in.Try doing a factory reset or a repair via PCC/SUS
Please mark
rotates for me whenevr I wish....
Yes, me and my friend are facing the same problem it only rotates while charging .. even after repairing !
also experiencing it, but what is the problem with it?
performed a factory reset(but not for this issue) 2 days ago, now it doesn't rotate at all. even when charger connected.
It's not a problem, but neverthless a feature that makes UI experience better.
Maybe it works only with charger, because it's some sort of special feature for charging dock??
happens to me as well. I wonder why!!!!
uninstall the latest update on SmartConnect and it will work
I've already done that. In fact, I've disabled the liveware manager long back. It's nothing to do with that, I guess..
