Home screen rotates to landscape in ICS, but only when charger plugged in .anybody noticed this?
or Am I the only one who is facing this?
oh I disagree, you can check this thread
wich app?
Yes, I uninstalled "Liveware manager" and restarted my phone. now auto rotation problem while connecting charger has gone. thanks a lot. dude.
@pradeeprk4 wrote:Yes, it's something to do with that app. I re-enabled the app and cleared the data, and it's working. Rotates to landscape without problems.
