For all those with battery problems,try this and see what happens
profile.country.RO.title
_alexdon_
My friends, i can see you have many problems with the batery life. I don't know if any of you has noticed this, but when the phone is charging and it reaches 100%, you shouldn't remove the charger. The phone is still charging even after reaching 100%,sometimes for half an hour. If you want to see when the phone is fully charged, go to Settings-About phone-Phone status. In the first field you can find if the phone is or is not fully charged. Try this and let's see what happens. I hope i can help some of you.
alexdon
205 REPLIES 205
florenzgonzales
its ok alexdon no prob, dude what do you think about xperia z?
sonyxperianeolk
doesnt the greenheart charger stop chargin at like 100 %?
sonyxperianeolk
so the greenheart charger says it stops when its fully charged would the phone be fully charged at 100% but still shows charging
florenzgonzales
Wait till its says "full"
_alexdon_
yes,when the phone is full charged,it does not charge anymore.
alexdon
_alexdon_
I think xperia z is one of the best terminals sony has ever made,i am impressed by its configuration.But still,have you seen SGS4?OMG!!!!Octocore processor for every situation,2 GB RAM,an impressive fellow.
alexdon
florenzgonzales
man how fast is that..dual quad core sick! but atleast xperia Z still has its water and dust ressistant right. but yeah SGS4 is just a killer
harm_jack
Can someone help me with this? Just 4hours of battery life, drops from 65% to 8%
this ain't normal right...
florenzgonzales
probably not normal..
try doing this:
1.turn off your phone and charge it while its off. wait until its full and turn it on and observe if the problem still perssist.
2. turn off wifi, bluetooth, data traffic, acounts auto sync, location, NFC, turn everything off and observe if your battery will last longer.
3. if still proble occur, repair your phone using PC Companion or SUS here:
http://www.sonymobile.com/gb/tools/pc-companion/
harm_jack
I did step 3 yesterday but it doesn't seem to work. I will try step 1 and 2 but i don't think it will help. My battery will last little bit longer but i don't think it will solve the problem...
this is the result after i did the repair and reset thing yesterday: Android thing is still using a large amount of my battery as you can see. Don't think it's normal...
