Fastboot problem
berenjian
Fastboot problem
It's one of the worst phone!!! No fastboot mode !!!! when i push volume up and connect it to PC , Blue light after several seconds changes to red and go in charging mode!!! Android is one of the best , but not on Xperia families....:smileyangry:
What should we do!!!!!!!!??????
Thommo
You should open device manager and check the driver is installed when entering into fastboot and if not then as you would do with any manual driver installation - Right click said missing driver and choose update or you could have check the Sony site for the Fastboot driver http://developer.sonymobile.com/downloads/drivers/fastboot-driver/
4 REPLIES 4
Thommo
berenjian
But my Xperia SP doesn't go on recovery mode. When I press volume up repeatedly (when sony logo appeard) nothing happen. For this problem what should I do?
Thommo
There is no recovery mode on Sony devices - unless you have your device switched off then holding volume up connect your device to a Pc via the usb cable then and only then will Fastboot mode work, you could try Flashtool and ask it via it's options to reboot into Fastboot mode
berenjian
Aw..useful! Thank you...
