Customize LED notification - LED notification only for calls and smses - not for emails and FB
kosiara
Hello,
On HTC One I had the ability to customize for which notification "types" the LED was flashing. It was called:
"Flash LED for notifications:
- Calls
- Voice mail
- messages
- callendar
- mail
- alarms
Can I do the same with Sony XPeria SP? I want my LED to flash for calls and smses.... but I want to disable the LED for all other notification types.
I other topics I found an app:
https://play.google.com/store/apps/details?id=com.rageconsulting.android.lightflowlite
Will it work with Sony XPeria SP?
Thanks,
Bert
tecboy1
Yes u can got to settings display - light effect
3 REPLIES 3
tecboy1
You can access the settings on each app and uncheck notifications
kosiara
Yeah... there is option for calls and smses... It would be handy, however to have the option for emails as well! Nevertheless, thanks for the tip!
