Well problem was USB socket.. I replace it and it fixed
(couldn't find SP orginal socket..used VIVAZ usb socket)
also no data connection with pc by cable
well, unfortunetly there is no sony customer care in Iran
so i do it my self
there might be a problem with the usb port. maybe you can have it checked at any trusted mobile repair shop
gioing for changing USB port .. will report back
my sony xperia c5306 won't charge even after i changed my battery. The battery when replaced had 60% and i tried charging but it didn't charge.I went to check the battery information while plugged, it wrote not charging. I have tried all best and strong chargers i can, it still persist. please what can i do
