charging problem
Danial-mach1
Leader
charging problem
Hey guys
im backed:-p
couple days ago my phone charge drained completly..and goes off
after this it won't charge..i try with 3 chargers..force reset ..even i changed my battery but still the same..new battery have 65% chargeit self..but conecting to charger won't charge it more
any advise?
Danial-mach1
Leader
Well problem was USB socket.. I replace it and it fixed
(couldn't find SP orginal socket..used VIVAZ usb socket)
9 REPLIES 9
Danial-mach1
Leader
Sorry i can't edit my post
the phone don't even heat up when charger is pluged in
but the red light goes on
profile.country.PH.title
MarlonUk1
Try yo charge it with the wallmount adapter. Leave for 3 hours. . Then try to connect pc. If necessary perform software repair using Xperia companion
Danial-mach1
Leader
I leave it for almost 12 hours
just go for data test
could it be connection cord or feed ic?
(Try them both, not found something similar)
MarlonUk1
I suggest to have your device checked at your local service center http://support.sonymobile.com/global-en/contactUs/
Danial-mach1
Leader
also no data connection with pc by cable
well, unfortunetly there is no sony customer care in Iran
so i do it my self
Tags (1)
MarlonUk1
there might be a problem with the usb port. maybe you can have it checked at any trusted mobile repair shop
Danial-mach1
Leader
gioing for changing USB port .. will report back
Danial-mach1
Leader
Lucucszy
my sony xperia c5306 won't charge even after i changed my battery. The battery when replaced had 60% and i tried charging but it didn't charge.I went to check the battery information while plugged, it wrote not charging. I have tried all best and strong chargers i can, it still persist. please what can i do
