Thanks!
I bougth a new battery and solved the problem. Now my phone is working fine.
3G will drain your battery faster then 2G, double check if there's poor network coverage in your area, also go to
settings > battery > check what has been using up your battery. If you are syncing multiple apps, accounts, etc, it will drain faster.
@uliwooly wrote:3G will drain your battery faster then 2G, double check if there's poor network coverage in your area, also go to
Thanks!
I don't think is a problem of 3G, because it happens in few minutes, sometimes in secconds that the drain is very fast until it turn off. Also, there is good signal. Other phones work well in the same location.
I'll wait for some other responses.
