Hiya I found the setting once but cannot find it again, theres a setting where you can keep the phones display awake whilst charging, I had set it to on but now I want it off now when charging - does anyone know what heading in settings its under please? Thanks.
It is hidding in Settings>Applications>Development (if it didn't run away) :smileywink:.
Go to Settings> Applications> Development and uncheck the Stay Awake option.
Thanks thats where it was - it would have been too easy for them to put it in the display settings area!
Didn't run away, but can't select it on mine! It's there but not highlighted so can't select it. Suggestions? (besides rebooting, clearing mem etc.?)
