I have purchased a Sony Xperia Tipo mobile 20 days ago.
I am highly satisfied with the features and the build quality.
But recently, my phone is troubling me by displaying a red border around the screen.
It is not a continous one and appears only if i enter or exit an application. (lets say message inbox)
Restarting the phone didnt help. It is annoying alot and appears to be a serious issue.
Have a look at the attachment and provide a solution.
Ravi.
Have you tried this?
Settings > Developer options > remove check on Strict mode enabled.
Hello,
I have similar problem; RED BORDER when I touch screen.
Other issue like very poor battery, Speaker quality is bad.
Phone hangs up and doesn't respond to touch on few occassions even when all applications are disabled.
I want to contact customer care.
Please contact me on drvijaykamat@gmail.com
or call me on +91988669267
Thank you DizerX, works like a charm.
Turning the option off and restarting the phone, didnt show the red border again
I have just got a Sony Miro and mine has been doing exactly the same, so I unticked the box in developer options and restarted the phone which has fixed it. Phew, I was worried it was a software problem and I would need a new one, what a strange function to have on a phone. I have had dozens of phones over the years and never come across anything like this before.
Thanks for the advice.
it works for me. Thanks a lot
Thanks a lot .It helps me
thank you
Red Border problem is solved by your help. Thank you so much .
