Does anyone hve problem with 2g in jb update . It seems slower . Nd stops many times.its slower than ics much much slower. Are there anyone else have thia problem? Plz say. I m frm India
i did everytinh i can possibly do:smileysad: no use
I activated a 3G pack for same price of what i used to pay on 2G So im enjoying JB now haha !
what how much?
hey...is ur 3g of vodafone?? I have a 2g connection of vodaphone and its painfully slow... does 3g help??
See i was using on postpaid 199 rs 1.5gb on 2G..but i have wifi at home so i hardly used to use 80mb max to max on 2G, hence i took the 3G 500mb limit plan for 200rs and it works awesome Indian users specially vodafone are having 2G issues @pauli..ppl on airtel or docomo dont seem to have this issue!
would a 3G connection help then??? I am currently n 2G and its as good as non-existant...
As i said 3G works perfectly on JB dude! I Know it jst connects and shows E and nothing happens..this is not the case in 3G its perfect!
canu guys try turning on airplane mode for couple of minutes and then turn it off and test 2G? Port speedtest results here.
Could you please send me your details in a PM, and I will forward this.
Make a relevant topic and include the following.
Name:
Phone nr:
E-mail:
Country:
Operator:
Product(s):
IMEI nr:
Build number:
did someone try this?
