2g works slower in jb much slower
uber_cool
Does anyone hve problem with 2g in jb update . It seems slower . Nd stops many times.its slower than ics much much slower. Are there anyone else have thia problem? Plz say. I m frm India
Johan
Master
That post is regarding the NFC problem discussed in the NFC problem thread. The 2G being slow is something that is still being looked at.
87 REPLIES 87
shiva_8977
I too am having this exact problem but no one is bothered to help regarding this Slightly_frowning_Face
have you check the basic? apn settings, network coverage? perhaps download an app to test your network and/or speed.
shiva_8977
Apn settings yes, with same network coverage on ICS it used to work great. Many people from India are facing this problem as far as ive read through Slightly_frowning_Face used speedtest and it showed 141kbps speed but whatsapp msgs dont go playstore doesnt open!
if you or anyone want to downgrade and check the speeds and then reflash to double check that will be the way to go
uber_cool
2g is digusting  its slow like hell . Even whatsapp  facebook messenger doesn't works   plz find a solution to this
shiva_8977
Im getting 99kbps on ICS. Already downgraded back because of this issue.
shiva_8977
@uber_cool are u on vodafone network? Where in india are u from?
uber_cool
Mine too in Vodafone nd me to downgraded to ics  is the problem with vodafone network or Rom?
shiva_8977
I dont know ..ppl say 3g works fine on jb.. It could be the rom i suppose cause on the same network but different rom everything was fine..im thinking of calling vodafone customer care just to be sure Neutral_Face
