Does anyone hve problem with 2g in jb update . It seems slower . Nd stops many times.its slower than ics much much slower. Are there anyone else have thia problem? Plz say. I m frm India
It doesnt work fine..it works a bit laggy..just see if u can make out !
Ha ha lol. Really god knws wat sony is upto. Sony we stay in house nt outside:smileywink:
Ha ha sony going nuts. RI. Sony
i was wondering if there really is a 6.2.A.0.200 version perhaps it fixes our 2g problem
that might be a network coverage issue, have you contacted them?
Hi Shiva,
JB update is really good where 2g and 3g are fast comparing to ics around 280mb apps got installed in 10 min, i'm using airtel see the below speed result
WHICH SERVICE PROVIDER ARE U USING?
Airtel and 2g also damn good, for last one day i'm in JB which is running smooth, some say video is lagging which i never tested.
Regards,
Andrew
I am not facing any data connectivity problems, either. In fact, it's a bit faster on JB then it was on ICS. And yes, I'm talking about 2G data connectivity, here.
