Condividi la tua esperienza!
Its hard to say if that's normal or not depending on your current total battery remaining. If you're down below 15 % of total remaining battery there may be something wrong and you might want to consider reinstalling the phone via SUS.
How long have the phone been powered on?
You can see this in the very same battery stats that you're looking at to see the screen consumption.
You can also press screen here to see how long the screen has been on. Compare this with how long the phone has been powered on and consider your screen brightness.
