battery and LED problem
boyboy
hi all dear,i having a problem about my battery,why the battery so abnormal,always keep 100% at battery indicate but never deducted after use few hours,or maybe drop until 95% or other battery level it will jump back to 100%,so obvious.and also normally put battery charging will be indicate red colour LED at bottom,but it become green,even i take out also still remain green(actually without battery to put charger should be no LED).i really fed up.please anyone have any idea about my problem.thanks
*my phone updated to latest version and also repair using SUS but still nothing helped.
You might want to take it back to the store or a Sony repair center
2 REPLIES 2
boyboy
i would try it,tks uliwooly
