Hi
Had the amp for about 18 months now and never had an issue. Recently the display on the amp can't make it's mind up if it wants to be on or not. Sometimes when I switch the amp on the display works for a while, goes off, might stay off or come back on, it's kinda pot luck ![:slight_smile: :slight_smile:](/html/@F913F597BB21E9159B8BC337FD3DA8FB/images/smilies/011.png)
Before I take the amp to bits to check cables and for dry joints, has anyone else had this issue??
