Hi there
On the TV's remote control, Press the blue HOME button and goto: Settings > Digital Setup > Audio Setup
Then there is an option for Audio Description. Set it to OFF.
As per pic below:
HI,
I have the same problem with a BDP-S790 Blu Ray player.
I can cycle between the various soundtracks but can't find any option to turn off the audio description. It's driving me nuts!
Thanks !
Hi there
Are you sure your not meaning audio commentary?
Anyhow - I thought audio description is on the disc itself - so it may be on the disc's audio menu settings itself.
Try turning off BD Audio Mix in the Audio settings and see what happens.
