BDV-E370 Surround sound problems
zbysiu909
About two weeks ago I noticed that the rear speakers on this 5.1 system weren't working (they had been pumping out sound quite happily prior to this). Whe I play a BluRay disc sounds come from these speakers. I did a Tone Test, and sound comes from these speakers, but when watching tv (Sony KDL-32EX713) or the feed from my Sky+ HD box, the speakers go quiet on me. I've reset to factory settings, gone through the setup again but no luck.
Has anyone experienced this, or could you maybe suggest a possible solution? The only thing I haven't tried recently is to see if the software is up to date, however, the unit is constantly attached to my router and when I last checked about three months ago the software was up to date.
5 REPLIES 5
Bravia55HX
cant speak for the SkyHD box but the system is working fine, most terrestrial broadcast are in two channel audio unless a banner pops up to say its in surround sound, you say a sound test and with Blu Ray it works fine so dont worry about it.
zbysiu909
The reason for my enquiry is that all speakers were active up until about 3 weeks ago, so I don't understand why the rear speakers should have stopped working/emitting sound). I haven't had time to sit down with the manual again so I'll work my way through everything again.
Anonymous
Hi there
Can I point you to page 27 and 28 of your manual. This is in regards to changing the surround sound setting. Try setting it as A.D.F. Multi.
A.D.F Multi
• 2 channel source: The system simulates surround sound from 2 channel sources and outputs sound from the 5.1 channel speakers by duplicating 2 channel source sound across each speaker.
Hope that helps
zbysiu909
That's the one! Thanks. Now to find which little fingers have been "experimenting".
Bravia55HX
and its AFD (Auto Format Decode) :wink:
