Please help: Dolby Atmos X90J and Denon x4400h
MartinPie
Hey everyone, I’m totally at a loss and hoping someone might be able to help me.
I have an X90J and whenever I play atmos Netflix content from my x90j, the Denon amp says the input signal is Dolby digital +. I have a 5.1.4 setup and appears all ok on the amp.
I have a Blu ray player connected direct to the amp and when i play atmos content up comes atmos on the display as the input signal.
I followed this similar guide for the A90J https://youtu.be/NkS88Ot93VE
In summary I have:
eARC mode auto
Dolby digital plus output set (when I toggle this the Denon switches from Dolby digital to digital +
Pass through mode auto
Digital audio out auto 1
Hopefully someone can help!
thanks
MartinPie
Turns out a factory reset on the TV did the trick, I didn't need to configure anything on the X90J just go through the setup process (detecting the external audio system)
Opened netflix, played some atmos content and there it is input source "Format Dolby Atmos/Digital+" that's on the Denon app. The amp just says "Dolby Atmos" 👍
3 REPLIES 3
Marino.Manolo
Atmos is conveyed on Dolby Digital Plus, it is possible that the Pass-through sends Denon the DD + format that carries Atmos.
MartinPie
HannahEd01
@MartinPie, glad to hear this. Thank you for updating the thread.
