How can I turn of the camera tone when I take a photo?
Open the camera, click the cog wheel for settings, the scroll down a bit to Common and there it is, Sound.
@RottenFoxBreath @ParoKi also notable that on some markets, it is not possible to remove this tone.
/t5/Xperia-ray/Camera-shooting-sound/m-p/119810#M1357
/t5/Xperia-XA-XA-Ultra/Turnoff-camera-click-sound/m-p/1150894#M687
That used to be true, and was the case in the UK at one point, but for a few years now the camera sounds seem to be able to be muted.
And I remember that was due to privacy laws.
Hi @ParoKi,
Did you find the setting to turn the sound off? If it is not available or it's greyed out it's due to national/regional privacy laws and as far as I know, the only way to remove it is it set the device to silent/vibration mode.
Hi @RottenFoxBreath,
Very interesting to hear that this was the case for in the UK a while back.
The only country that I know about that has these rules are Japan, unless they have changed it recently.
Sorry for the late answer.
I still can not turn the camera sound off. There is no option when I look into the camera settings and the sound does also not disappear when I turn off all the other sounds. Maybe it is just not possible...
I live in Austria.
Here is what I see in settings
As @Jonas mentioned the cameras will shut the shutter sound in 'do not disturbe' mode.
Hi @ParoKi, I'm sorry for the late reply, I have been out of office due to vacation.
Do you not have the option available in your device if you follow the screenshot that @Strampke posted? Open the camera app > tap the cogwheel in the top right corner > check for "Sound" and turn this off.
As I mentioned, due to laws in certain countries you can't turn this off but since I don't live in Austria, I'm not quite sure if there is such a law there.
You may want to check with your Local support team as they are the experts on your market and may be more informed than I am about this.
Let me know how it goes!
@Jonas,
I'm sure from memory, this all started from Japan, and it's love of upskirt photos.
After that, certain countries and networks stopped the phones from muting, so the intended "victim" /witnesses, would be aware that a photo had been taken.
