Android 10 and ability to charge the phone
Dean6911
Hello,
I updated my Xperia 1 last week and realise the phone will not charge with my regular office charger.  It used to be able to,
If I were to reboot the mobile, the charger will then be able to charge (LED comes on, AcuBattery confirms charging).  But once I disconnect the USB charger, I can't charge it anymore unless I reboot the mobile.
My Stamina mode is on all the time.  It does not make a difference if it is switched off - I can only recharge the Xperia 1 if i were to reboot it.
Charger works on my Xperia XZ without any problem and before the upgrade I had no problem with charging my Xperia 1 on it.
Any advice will be much appreciated.
2 REPLIES 2
CastleberryPam
@Dean6911 wrote:
Hello,
If I were to reboot the mobile, the charger will then be able to charge (LED comes on, AcuBattery confirms charging).  But once I disconnect the USB charger, I can't charge it anymore unless I reboot the mobile mywegmansconnect.
wow, such nice update.
kelvinyang
have you set the battery maintainace option?
