Z5 compact dead! won't start, won't charge
Sophievh
Went to sleep last night with a fully working phone that I turned off. Woke up and it won't start or charge and bridge for mac can't find it either. And it's christmas so nothings open! HELP HELP pretty please anyone?
15 REPLIES 15
Phy
Legend
Legend
What I've seen posted on the forum, connect the phobe to a charger, then press and hold power and volume up buttons for 10seconds and let it charge for three hours.
Ashroft98
Enthusiast
Is there any blinking/glowing red light?
Have you tried repairing the software?
Open Bridge For Mac,find Software Update and press "Repair phone/tablet"
If nothing else could work try contacting about it to your local team
http://support.sonymobile.com/global-en/
Phy
Legend
Legend
If that doesn't work contact your local Sony Xperia support to get an evaluation.
http://support.sonymobile.com/global-en/contactUs/
Demelz
Thank you - I had the same problem and that fixed it - whew!
RichardGartland
Hi, I'm really hoping someone can help, I'm having a similar problem to those listed here. On Saturday I plugged my phone in to the USB of my PS3 to charge, it made a noise, PS3 said unknown device connected and it wouldn't charge. I connected to my charger and still it wouldn't charge. Since then it died. I have tried various things like the off button by the sim card once, and continuously for 2 minutes. This didn't work. I also tried the power and plus thing until light went blue, with varied success.. Today I managed to get 2% battery, then it died and stayed on zero. This evening I got the battery as high as 26% but now it is pretty much dead again. It almost seems like the battery is trying to charge out rather than in. I tried to connect to my laptop but it didn't register on the laptop so that isn't working either. I've now plugged back in with power and plus held until blue light was on, to see if I can fully charge somehow over night. I even tried factory reset to delete anything that was wrong software wise... Now it is still dead but has none of my info or apps either. Under warranty I need to send it to South Africa for a months so I really hope I can get it sorted myself here. Please help good people!
TattyAngel
Similar problem. No charge, won't charge. Sceptically but hopefully tried the hold power and volume button for 10 seconds and Wow, magic, it worked. Thank you 😁
compactuser
same thing happened to me. the solution worked like magic:smileyhappy:
Webalistik
Today my Z5C also stopped working.
First it froze using an app, then I used the 'off' button behind the flap. It then rebooted. But as soon as the home screen appeared it went black again and now it won't respond to anything.
Tried regular power on, pwr + vol up, 'off' button short, 'off button 120seconds', connect to computer while holding vol down, etc.
Nothing lets the device boot again. Also tried it all with the sim and sd card removed.
Unfortunatly you cannot take the battery out.
Any other secret key combinations I can try?
Mysteoa
My Z5 also doens't want to start. No button combination is working, no matter how long I hold.
