Z3 C microphone problem
sepprait
When I receive calls then microphone is not working for first 2 seconds and people can't hear me.
Is this some kind software problem or I should swap this phone for new one?
I mean it's sad but some times funny how my calls start like Skype calls where first thing you say is "Can You hear me?"
This problem have not occurred while calling out only while receiving calls.
That's rather odd, what if you re-install the latest update?
PC Companion (PCC)
Bridge (for Mac)
43 REPLIES 43
And this only happen while on skype or regular calls as well?
sepprait
No only on regular calls
But thease regular calls reminds me my usual skype calls when people can't hear each other Smiling_Face_with_open_mouth_&_closed_Eyes
How is your network coverage? settings > about phone > status > signal strength
how old is your SIM card?
sepprait
I got new sim card with my phone 10 days ago.
signal -83dBm 15 asu
That's rather odd, how about
Settings > call settings > microphon noise suppression (turn it off)
sepprait
already turned off when i first found out this problem
PC Companion (PCC)
Bridge (for Mac)
Georgepetrov137
What happens with this problem? I found the same problem with me. As well as other phones. Is there a solution?
themrnicky
I also have this problem with the microphone. started working after 2 seconds also during a conversation interrupted for a moment.
