Z1 campat warmer after reset?!
Ibaneza
Hi!
Today I did a hard reset on my Xperia Z1 compact, to fix a few smaller troubles.
After that, the battery takes longer to charge, and the phone is warmer, all the time, than it used to be. Not really hot but definitely warm. What's happening?
@Ibaneza
Try a different wall charger and turn off the device, I doubt that resetting the device cause this.
@Ibaneza wrote:
Thanks... I need to charge to 80% to do the repair on xc, and it just won't charge!
Used to take approx 2 hrs from 15% to 100%.
Now it hasn't reached 50% after 4 hrs... 😞
6 REPLIES 6
@Ibaneza
Repair the phone with XC and report back
Xperia Companion (XC)
Software Repair Guide
Ibaneza
@Ibaneza
Jonas
Master
Hi @Ibaneza,
I'm sorry to hear about that. Slightly_frowning_Face
You may experience that the phone gets a bit warmer after completing a factory reset or software repair, this is because the phone has to synchronize with all your accounts, update applications to the latest version and so forth.
As @uliwooly suggested, try charging the phone when it's either turned off or while it's rebooted in safe mode to make sure that a third party application isn't the cause of the phone charging slower than before.
According to the specifications it should take around 3 hours to charge the phone from 0% to 100% with the charger that was included together with your phone.
Let us know how it went! Slightly_smiling_Face
Ibaneza
Thanks!
Tried another charger and it was back to normal. Everything working now.
Jonas
Master
Thanks for the update!
I'm happy to hear that it's working again! Slightly_smiling_Face
Let me know if there is anything else I can assist you with!
