Don't create duplicate posts, as for your issue, I'm sorry to hear that but the phone can't bend on it's own without an external force.
You can google any brand and any issue and you will see users claiming that it happen by itself, the phone can't bend on it's own, I'm sorry that this happen to your phone but perhaps you sat on it, perhaps you drop it, perhaps you kept it in your front pocket and somehow applied too much pressure that it caused this.
Keep in mind that this is a user based forum, contact your Local support
Not any other condition applied phone automatically got bend neither i sat nor i applied any force.
and if not in front pocket then where should we keep mobiles phones.
And I used many phones and kept in front pocket but any of them didnot bend so why to make such weak body that bend easily.
Its manufactoring fault.
I disagree, but you don't have to convince me, this is a user based forum, keep in mind if the back or front were cracked, it will compromise the phone, in other words, if there were cracks the phone can bend a lot easier.
