Xperia Z2 magnetic charging problem
kilic-f
My Sony Xperia Z2 magnetic charging with the docking station worked fine for the first 3 weeks but the last todays i get the next problem:
http://youtu.be/Fm_hTXNJ0jg
Solutions??
18 REPLIES 18
edika
I'm having the same problem with my Z2 phone and Tablet. The phone has been changed with a new one by Sony but after 3 week the prblem start again.
Now every time the problem is present I have to hard reset the phone/tablet for 2/3 times then connect directly to the USB port to start charging normally.
This problem is never püresented with my Z3 phone, so I think is a software related prblem of the Z2 line.
Demon1521
I had this problem when connecting to usb 2.0. Try 3.0 ( if charge from PC), If use puwer supply, try connect dock with phones charger and cable.worked for me.
MAQRYK
Another forum naming "Lollipop charging bug" addressing the same problem. please check it as well.
Demon1521
Connect charging dock with phones original charger and cable, should work. It flashing because it needs more power. If charge from PC try 3.0 USB, or those what is in PC back.
RamaMollo
I had the same problem on my Z1s phone. I think the problem was that one time i connected "inverted" the magnetic charger and because the charger had polarity, maybe some diode or other electronic component broke.
Could be this possible?
Someone could solve this problem?
Tks!
RamaMollo
Pedrosimoes18
Im have the Same problem today it only charge to 90% and the dockingstation smells like it is burnt inside
Rostan
I had the same problem also it would blink connected then disconnected with the USB and never charged past 80% on usb. I could never get the magnetic part to work but a factory reset and using only very tight fitting USB allowed me to charge it to 80% with the USB.
Sony-XperiaZ2
I have same problem Slightly_frowning_Face I can't charge my Xperia after 94%...
What I have to do? it's software problem? or may phone is damaged?
xperiaso-03f
The dokcing station worked fine in the first 2-3 weeks without this problem and the next test for me was to turn te smartphone off and try to charge it the result was : https://www.youtube.com/watch?v=rem9Oi4Wiiw
4-5 seconds charging this time with powerbutton and volume button option and in the first video it was from second to second with the charge (blink) problem
