I think I've only tried on FHD and HD. Will check a bit later for the last resolution.
Hi @robsonkxd,
Would it be possible for you to capture this in a bug report? If so I can forward this internally for further investigation.
To do this:
When the report is ready you will receive a notification. Tap the notification to share it. I suggest you upload it to Google Drive and then send choose to share a public link to the upload and include the link in the PM.
Please also include the following information.
Name:
Phone numberr:
E-mail:
Country:
IMEI:
Build number:
I've done just that
Thank you. I have forwarded this internally and will let you know when I know more.
Wow, I have not upgraded to Marshmallow yet, because in Spain it has not arrived, but other people told me they had the same problem with the Z2 in Marshmallow, so it is not only only problem of you, it is not only your phone, thre are more Z2 affected. I think it must be soved because I think it is one of the most useful and best features of the phone.
