Xperia Z2 D6503 "Record Screen problem"
robsonkxd
After updating to android marshmallow 6.0.1 on my Xperia Z2 D6503, whenever I try to record the screen, the record screen functionality stop working (it force closes). I've tried to clear the data for the app and the problem hasn't been resolved. Help and thanks in advance.
Christofer
Champion
I'm very sorry for the late reply here but I've now received information about this. I'm afraid that the screen recording feature has been removed in newer products and for this reason it is no longer being developed. If you rely on the screen recorder I recommend that you search Google Play for an app to use for this.
21 REPLIES 21
@robsonkxd
Does it work in >>> safe mode ?
robsonkxd
I've never tried it in safe mode. Let me do just that then I'll give you the feedback.
@robsonkxd keep us updated
robsonkxd
Just did that and it didn't work. The problem still existsScreenshot_20160510-083901.png
malakhi
I have same problem after updating to 6.0.1 ( d6502)
Yesterday i try record screen in youtube and i recived error screen recording ended 5 or 6 times then change qulity from full hd to hd and record from screen without error
Try and feedback
@malakhi @robsonkxd
This is another topic that @alexdon could test as I don't have a Z2
profile.country.RO.title
_alexdon_
I was able to replicate 2/3 times when playing around the phone while recording the screen. Will escalate this.
alexdon
Lord_viridis
Does it cut out during protected content or any time?
_alexdon_
@Viridis I thought about that but nope, once just by sliding left/right in the apps menu and once when just scrolling in settings.
alexdon
