Water Vapor stuck in camera lens
Mi2o
Hi guys i need help please after using my phone in water, some waper Vapor entered into in front and rear camera lenses i don't know how that happened but the phone is working perfectly
What should i do to remove it ?
Thanks !!
@Mi2o
remove the SIM and SD cards > open all the covers > place your phone in a bowl with rice > let it sit for 24 hours
Also, contact your Local support and request a vacuum test.
@Mi2o
