Setting SD card as default saving location
Automat-2015
Is there any way to change the default download location in Bluetooth?
At the moment, every time I download something using this facility, gets stored in the internal memory. But I would like to download directly to the SD card.
Unlike Samsung, I read that it is not possible to make such a general setting in the Xperias and it has to be done individually by app. but I can't see this setting anywhere in Bluetooth.
Is there any possible solution?
Tags (2)
profile.country.US.title
Qatrium
@Automat
As far as I know, there's no setting to change default save path for received files via Bluetooth.
2 REPLIES 2
Qatrium
@Automat
Jake-SonyXperia
Champion
Hi Automat,
What @Quester has advised is correct, Bluetooth on our devices has always saved to the internal storage, and there is no way to change this within any normal means.
