SD Card not accessible after encryption
elophant
Hello,
I am running Android 4.4.4 on my Xperia Z1 Compact.
I just activated encryption with the flag "Encrypt SD Card" set and with my SD card full of data (pictures, videos, etc.). I use a 4-digit PIN as the screen lock password.
After the encryption was finished and after restart of the device, a notification in the upper left says, that my SD card is either empty or has a not supported file system. Clicking on that only brings up the option, to format the SD card. But I do not want to do this.
The SD card is now not "visible" for the phone and I cannot access my photos, videos, etc. on it.
This problem was also reported elsewhere:
/t5/Xperia-Z3-Compact/SD-Card-issues-after-Encrypting-phone/td-p/851471
Any idea how to solve this?
Regards,
elophant
elophant
Hi uliwooly,
the SD card was not corrupted. I basically confirmed the message to format the SD card by the phone. After it got formatted, I connected my phone with the USB cable in MSC mode, so that it showed up in the Windows Explorer as a new volume.
It was actually shown as being empty and also had full capacity left. But then I did a deep scan with the program Recuva and it was able to restore nearly all files from the SD card.
So I conclude, that the files on the SD card haven't actually been encrypted nor have they been erased by the formatting after the encryption process.
Problem solved now.
Best regards,
Philipp
2 REPLIES 2
then the SD card might be corrupted
elophant
Hi uliwooly,
Problem solved now.
Best regards,
Philipp
