Well, I do not have an original sony UCH10 so I cannot say. But the aukey one did it's job for me. You need to consider that if the phone gets hot, it will eventually reduce the current.
You are welcome. Wanted to let you know that the Z2 won't experience a quick charge experience (only the japanese version does). @sgizmo
