All the quick chargers (2.0) have default charging voltage and amperage, some of them can raise the amperage more but it might be limited by the device itself.
But in gsmarena forum one dude says that samsung qc works when sony qc doesn't work. Why he is talking this if it not true. He is using german generic (not rooted etc) . Hm.
There are many other brands that produce QC2.0 adapters and cables. @Nabeel didn't you have a Samsung charger? Any input?
Aukey has both 2.0 and 3.0 compatible. Its something like this:
https://www.amazon.com/Charger-Micro-USB-Blackberry-Qualcomm-Certified/dp/B00QEX83LA
@sgizmo I have told someone to check how the samsung adapter works.
