You will have to begin recording, activate touch block and dive right in!
Probably because the buttons are being pressed. You must lock the screen so that water does not touch the screen. You can use the shutter button to take pictures. In order to lock the screen, open the camera app, press the options button, select the 3rd option (the one with the tools picture on it) scroll down and activate touch block.
Good luck and make sure all your flaps are closed:)
are you using the physical camera key?
you will have to activate touch block
Anytime, just make sure to always check if the flaps are firmly closed
Just curious: Have you recorded long 4k videos underwater? I've read that after about 4.5 minutes of recording 4k video (not underwater) that the camera shuts down due to overheating. I'm wondering if being in a liquid would enhance cooling enough to allow a longer video recording time.
