My Z5 Premium hang and become non responsive
Segovia
My phone suddenly hangs, become hot and all buttons and screens become unresponsive.
Is there any way for me to reboot the phone?
For my older phones, when that happens. I would normally plug out the battery but Z5 premium does not allow that at all.
Now I'm really concern and I'm thinking what should I do? as the phone is currently still radiating heat as I am typing the question now.
Do advise if there are any method to reset or restart the phone when nothing is responsive.
Phy
Legend
Legend
Press and hold the volume up button and power button for 10seconds or until the phone vibrates.
4 REPLIES 4
Phy
Legend
Legend
Segovia
Thanks a lot... it works!!!
Phy
Legend
Legend
No problem. Glad it worked.
yanii
Hi! I got the same problem, and thanks to their advice to you, it did work.
But just wondering, did it happen again to your phone? I was just worried that it might happen again and cannot be fixed anymore.
