Google: android apn settings __name of your carrier___
If you have wifi then you should be able to open Settings then More then Internet settings then tap Accept and select your operator which should then auto download and install the correct Mobile data settings
Glad you got it sorted
plzzz i need help i did everything that you said
but still doesn't work & i rest factory the phone
works for 1 day than it's stop again
THANKS!!!!
