What if you remove the SIM and put it back?
See this topic too:
/t5/Xperia-Z2/mobile-data-not-working-after-lollipop-update/td-p/956104/page/3
re-enter the APN settings manually
Settings > more > mobile networks > access point names > menu > add new > enter the info > menu > save.
