In "Battery usage" WiFi always reported as ON irrespective of its state
lchmiel
In "Settings | Power management | Battery usage | History details" WiFi is always reported as ON irrespective of its actual state. The bar related to Wi-Fi is always drawn as continuous, besides that sometimes WiFi is actually set off, or set on but currently not connected.
The power consumption of the phone is substantial. I fear that perhaps WiFi module is actually never switched off, but is only logically not receiving. If switched off it is repored as off by such applications like Network Info II, for example.
Any idea how to check why this happens?
Anyone noticed this problem too?
lchmiel
I know the solution. It was "Viber" which kept the WiFi always on. After setting the relevant option in Viber to off the problem disappeared.
7 REPLIES 7
profile.country.RO.title
_alexdon_
Have you tried to set scanning always available to off? You can find it in advanced settings.
alexdon
lchmiel
It is set to "off" all the time.
_alexdon_
Boot in safe mode and see if the same occurs.
alexdon
lchmiel
In safe mode the problem does not occur, in normal mode it reoccurs. So, it is time to check which application does this.
lchmiel
beboo
hello
i don't have viber
but the problem still exist
lchmiel
So this is some other application. Try to boot in safe mode as Alexdon proposed in some previous post.
Besides, in Android 6 the state of devices like WiFi, GPS etc. in time can not be observed in the "Battery" option in the settings. Pity.
