Hello,
on my sony xperia z1 phone i forgot my pattern lock. I can't use the Forgot Pattern Lock because it uses Wifi conection which i can't connect to...(my screen is locked) I want to hard reset it somehow but i tried allmost every method on the internet but none of them were working I tried holding the volume up and these things....but as i said it won't work for me. Can anyone please help me? THANK YOU VERY MUCH
In order to fix this you need to perform a system repair
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
This haven't worked for for me but i just got the password. Thank you for your reply. I LOVE MY PHONE
